GE AC with error code 88
Brand: GE
Model Number: AHC18DZH1
Main Symptom: turns on with error code 88 and then turns off
What happens & when: turns on with error code 88 and then turns off
Error Code (if any): 88
Parts or tests already tried: tried unplugging for to reset with no help
internet says replace control board and I found on your site, will this fix problem?
https://www.appliancepartspros.com/ge-ui-board-kit-wj26x27693-ap6994981.html
This is the part number for the main control, WJ26X22155 Air Conditioner Main Control Board | Genuine Ge OEM In Stock
