I’m searching for the gasket replacement part for an Imperial Heavy Duty Commercial Freezer (Model # UL2494ECW5). The door doesn’t seal completely, and I get a build up of ice and frost on the inside of the freezer. I’m also looking for the replacement key for the lock.
[QUOTE=bdcane;910303]I’m searching for the gasket replacement part for an Imperial Heavy Duty Commercial Freezer (Model # UL2494ECW5). The door doesn’t seal completely, and I get a build up of ice and frost on the inside of the freezer. I’m also looking for the replacement key for the lock.[/QUOTE]
BDcane
Did you ever find a replacement Gasket? Or the key? I have the same 2 problems. If I had the key, I could lock it tight. right now I have the door duct taped.
I am looking for the seal for model number UL4000ECW2
https://www.appliancepartspros.com/03-door-parts-for-frigidaire-ul4000ecw2.html
Seal is part #1
https://www.appliancepartspros.com/frigidaire-door-gasket-3206261-ap2132663.html
Is the door liner plastic cracking along the screw holes?
