Hello,
My dryer starts a new cycle ok. Later the flame turns off. I think this is normal and the thermastat watches the temperature. When the flame is supposed to turn back on, it will for maybe the first couple cycles but later doesn’t. Currently, I am measuring the blue and whit wires on the secondary coil. After the ignighter turns on, the flame sensor closes and I measure 120v on the secondary coil (blue to white). The primary coil is blu, whit and black. I am assuming that the black goes hot since it is the same electrical connection as the ignighter and I can see the ignighter glow. During the flame cycle I see the voltage between white and blue stays at 120v when the ignighter turns on and the flame sensor sees the flame the voltage drops to ~ .4v but no flame. The ignighter turns off, the voltage goes back to 120 but no flame. Can some one help me please?
Thanks,
JD
