Replaced the oven igniter. The oven igniter will not light up.I checked the ome through the thermistat so I know that is not the problem. I tested the wire where you plug the igniter in is that suppose to be 110 I am not getting anything.I would appricate your help. Thank You Fatassmo
[quote=fatassmo;568180]Replaced the oven igniter. The oven igniter will not light up.I checked the ome through the thermistat so I know that is not the problem. I tested the wire where you plug the igniter in is that suppose to be 110 I am not getting anything.I would appricate your help. Thank You Fatassmo. Ps I need help as soon as possible.
Replaced the oven igniter. The oven igniter will not light up.I checked the ome through the thermistat so I know that is not the problem. I tested the wire where you plug the igniter in is that suppose to be 110 I am not getting anything.I would appricate your help. Thank You Fatassmo. Ps I need help as soon as possible.[/quote]
