I have a frigidaire gas range stove model number: FGF378WCCA
The igniter sparks continuously. With the range lit, and with the knob in the off position.
I have replaced the module - MFG Part Number 316135702 - and it did not resolve the issue.
when I look at the wiring diagram there seems to be only one switch between the hot lead and the module. it appears to be the switch controlled by the knob.
do you think that I should replace this part: MFG Part Number [B]316032000?
[/B]
any other input or suggestions?
