Gas oven
The oven cuts on but I can not tell the temp or when it is off because the knob on the oven just keeps going ound and round even when I pull the knob off and turn the metal stem.
Oven control knob seemed loose. Then one day it would not stop in the off position but continued to spin all the way around. The Oven did not go off. I removed the knob, and tried to turn the metal rod to turn oven on/off. However, once on I had a hard time getting it to respond and to go off.
What should I do?
