Gas oven wont ignite
this oven wont ignite the range burners are ok
Does the igniter (#14 on the diagram) glow?
If it does then most likely the igniter itself is too weak to open the gas valve and has to be replaced.
If it does not, then you have to check if there is 120 VAC to the igniter while the oven thermostat calls for Bake and post the results.
Here are the breakdown diagrams and Replacement parts for CROSLEY C31113WAA RANGE- F/S STD GAS | AppliancePartsPros.com
Is this true even if the igniter glows? Our igniter comes on but the valve doesn’t open.
Thanks.
[quote=Kendall4570;845952]Is this true even if the igniter glows? Our igniter comes on but the valve doesn’t open.
Thanks.[/quote]
And if this is the case, what is the part number for this igniter?
