Gas Oven humming while heating
Brand:GE
Model Number: jgb630def1bb
Main Symptom:humming
What happens & when:oven or broiler only not range. Happens when flaming/heating/ and slightly after shut off (a few seconds). As if the hum correlates to the gas flow. Not the supply, already changed bottle; made no difference.
Error Code (if any)none
Parts or tests already tried:recently changed lower igniter. Noise was not present at that time. Does it regardless of lower igniter or upper igniter broiler being used. Heating is not affected so far.
That is probably the gas valve that is making that noise, I wouldn’t worry about it unless it gets to where you can’t live with the noise, WB21X20293 Valve Control Assembly (Control Valve) | Genuine Ge OEM In Stock
