Gas Oven Holds Temp Only w Top Burner On
I have a Whirlpool gas stove model SF315PEPW1 that is having an issue with the oven. We set the temp and the oven lights (sometimes takes 2 minutes or so to light…I’m assuming this is normal). Once the oven reaches temperature it turns off, but does not come back on unless I light a top burner otherwisew it just cools back to room temp. Now we bake with a top burner on low and the oven works correctly. What part needs to be replaced?
Replace the ignitor in the oven, and that will take care of your problem. Tom ApplianceEducator.com
