my dryer was running find after doing 5 or more consecutive loads with no problem and with down time between loads, it suddenly it threw a electrical breaker, I reset the breaker and it threw again upon starting dryer, I removed the on switch w/ coils and an appilance store owner tested them and said they appeared allright, he said it might be the drum motor, I have it all loosened up but can’t seperate it from the fan assembly, or can I see how it’s connected, any ideas
There is definitely an electrical short somewhere in the dryer. The dryer has to be tested with an ohmmeter according to the wiring diagram. Guessing is not a good way to fix anything.
Here are the break down diagrams for the Roper dryer Model RGX5635EW2
