Gas dryer
dryer does not heat, i replaced the igniter because it had no continuity, it still does not fire. it appears that it is not getting the right voltage to the igniter. any ideas
randy43
Check the thermal fuse on the back of the dryer for the continuity and replace it together with the operational thermostat if it’s open. The part number for the thermal fuse is AP3132867 and the part number for the thermostat is AP3131939
Good luck.
