Hi.
Remove the vent hose from the dryer and run one load. If that doesn’t make any difference - replace the hi-limit thermostat.
Simon.
Hi.
Simon.
[quote=Simon / APP Team;774972]Hi.
Simon.[/quote]
Went to test it today, and now the gas won’t come on at all. Took the wires off the high limit thermostat on the burner duct and checked for continuity – the switch is closed at room temperature. With everything hooked up, the ignitor comes on for 8 seconds, then it shuts off. What can be wrong? What else to check?
Hi.
If the ignitor cycling on/off but there is no gas - replace the control coils AP3094251
There is a small chance that the gas valve is bad and cause the coils damage but consider the price try the coils first.
Simon.
