I pulled off the panel to check ignitor etc. Gas flame lights at start. Stays on long enough for a spoon shaped deflector to glow red and the dryer drum to feel pretty warm.
The flame shuts off and after a few more minutes the ignitor glows repeatedly but the flame does not light again. Every time I run the dryer, the flame ALWAYS lights the first time and NEVER lights after that.
I tried a new radiant heat sensor but the symptons did not change.
The gas burner unit has 2 valves with 3 coils. The whole assembly is Whirlpool p/n 349621 with propane conversion kit p/n 239072. The valves are called “1 & 2”. Valve 1 has two coils and 4 wires, called “HOLD” & “ASS’T”. Valve 2 has a simple coil, just 2 wires. Valve 2 is wired in parallel with the radiant heat sensor.
I removed the valve 2 coil to check. No visable problems, very clean and like new. But the actuator shaft isn’t free in the burner unit. At rest, the metal rod cannot be pushed further into the valve body. I am OK with that, it is probably in the closed position. But it takes a firm upward pull to draw it into where the coil would be. It is smooth, not sticking, just high effort. I am not sure the little coil can pull against that effort.
I did not remove the valve 1 coil. It is not hard to do, but I am not sure I am getting closer to fixing the dryer by doing so. I will wait for some advice first.
I do have an electrical diagram and I am trained at following them and making voltage checks. I can make leak tight plumbing connections too. I have rebuilt many different makes of solonoid valves. But my combustion equipment is very different from a home appliance. I don’t understand the 2 valve 3 coil design. I am only making guesses. It looks like they are trying to vary gas flow for a smooth safe ignition and then a different flow rate once flame is established. Like the ignitor causes the heat sensor to open circuit, allowing current to flow through the valve 2 coil and ignition.
Please suggest what to do to fix this dryer. You have a Whirlpool coil replacement kit, your part number is AP3094251 for about $15 and your replacement burner valve assembly is AP3094285 for $141.05 I hope I don’t have to buy the more expensive part
Thanks for any help you can be, “Patch0101008”.
