Gas dryer will not ignite
Dryer will tumble and igniter will glow, solenoid will click but no flame. I have verified that gas is flowing with no leaks or blockages and have replaced the thermal fuse and the 2 solenoids. I have also removed and checked the continuity on the igniter, flame sensor and cycling thermostats. Everything checked out okay. I let it run for about 30 mins and the igniter would glow the solenoid would click and nothing. It would cycle through this sequence intermittently. What am I missing?
I put the lower panel back on and reattached the vent hose. After running for about 5 minutes the flame finally ignited.
