Gas Dryer whirlpool
I have checked all sensors and they check out ok. I have put on new solenoid coils on the gas valve. I took off the out side plug and got gas from it. I checked the igniter and the end was broke. I know I do need to replace the igniter but will that stop gas from coming out of the little hole to the Chanel going to the igniter? Thank you for your help.
[QUOTE=Lachris;698954]I have checked all sensors and they check out ok. I have put on new solenoid coils on the gas valve. I took off the out side plug and got gas from it. I checked the igniter and the end was broke. I know I do need to replace the igniter but will that stop gas from coming out of the little hole to the Chanel going to the igniter? Thank you for your help.if you have a good idea of what is wrong please list the parts as well.
