I replaced the igniter and I replaced the 2 solenoid coil.
I checked the thermal fuse, the heat sensor as well as the cycling sensor. They all checked fine for continuity.
This is what is happening:
I start the dryer and everything looks fine and running.
The igniter get’s to be bright/white/orange for about 20 to 30 seconds and then fade out but not lighting up the gas (that’s why I replaced the coils in the first place thinking that they were defective)
Since I tried a few time and could smell the gas i held a long gas lighter on the side of the burner (on the other side of the igniter) and the burner lights up once the igniter is almost all faded out. the flame is powerful and blue.
The dryer exhaust is clean and everything else seems fine.
I am at a lost of the problem is.
Why would the coils not being in sync with the igniter?
Please help! Thank-you.
Hello.
If the igniter you replaced look like this
AP3109449
check if it’s installed properly.
If everything looks OK, then the only other thing comes to my mind is bad safety gas valve.
The safety gas valve AP6007556
Her are the breakdown diagrams and Replacement parts for Maytag MDG7400AWW DRYER- GAS | AppliancePartsPros.com
Keep in mind - you can always return any unused parts even if they been installed.
Thank you. Post the results.
[QUOTE=Simon / APP Team;699789]Hello.
AP3109449
Thank you. Post the results.[/QUOTE]
Hi Simon,
Thank-you for the quick response. Is there a way clean up that gas valve? I hate to spend any more money especialy after I already replaced the coils and the igniter.
Thanks again!
Jacques
Hi.
At the end there is bronze color orifice. Using a pin clean the opening. That may help.
The good thing is you can return any unused parts purchased from APP.
Good luck. Post the results.
