My gas dryer isn’t heating up. The drum is turning around though. What’s up with that:confused:
Can you be more specific on the problem? It does not dry properly, or it does not heat at all, or does heat at the beginning of the cycle and then stops?
Here are the breakdown diagrams and Replacement parts for MAYTAG MDG2600BWW | AppliancePartsPros.com
