Unplugged the disposer to do a water filter change but when plugging back in, the disposer started up and will not stop running. Never touched the wall switch. How do I spot it? The reset button doesn’t seem to change anything.
You’ve probably checked this already, but did you plug it back in the right socket? Usually, you would have a double socket under the sink where one socket is controlled by the on/off switch (for the disposer) and the other is always on.
I did exactly as you suggested, plugged it back in the socket that is always on. I didn’t know that is how the under the sink duplex is set up. Thanks for your response.
Awesome. Glad to hear you got it solved.
