Disposer hums, jams, leaks, or trips the reset? Get DIY guidance here.
Post title must be: brand + full model number + horsepower + main symptom
Example: “Moen GXS75C 3/4 HP leaking from bottom”
Body checklist:
• What happens when you flip the switch
• Any reset-button or hex-key attempts
• Location of leak (sink flange, side port, bottom)
• Age of unit and installation details
• Parts or tests already tried
• Photo of the leak area or jammed chamber
Before posting, run a quick search in this forum to see if your issue is already solved. If you suspect a bad part, paste the exact AppliancePartsPros.com product URL so others can confirm it fits your model.
