Garage Refrigerator Heater
[COLOR=blue]Does Roper make a garage heater for a refrigerator that is kept in the garage? or is there a after market heater ? :cool: [/COLOR]
Which part do you mean?
[quote=Gene;159762]Which part do you mean?
Gene.[/quote]If you are talking about the freezer or refrig? It’s both. The refrig is running to cold and the freezer is to warm. GE and other manufacturers have adressed this problem.
I do not know what is a “garage heater”. Can you be more specific on the problem?
[quote=Gene;160568]I do not know what is a “garage heater”. Can you be more specific on the problem?
Gene.[/quote]Google Garage refrigerator heater. Its a part that suppose to help a refrigerator work properly in a cold climate like a unheated garage in the midwest.
Sorry, I’m in California and never worked in a cold climate. Maybe somebody else on the forum can help you better.
Check out the following
http://forum.appliancepartspros.com/refrigerator-freezer-repair/63086-refrigerator.html?highlight=garage
It is for a frigidaire but you should be able to get it to work on your unit.
[quote=denman;161019]Check out the following
It is for a frigidaire but you should be able to get it to work on your unit.[/quote]I saw the frigidaire model when i goggled heaters, I called and was told its only for frigidaire,but when I think most things can be fix with duct tape, a hammer, and a few word choice words. It might be worth the price to give it a shot. Thanks!!
