The top oven is not working, when you turn it on the light inside will dim then click and brighten again???![]()
Hi Moose,
In which mode did you use it?
On all modes last night I took apart the front top panel just to look and tested the fuses one is burnt out, any idea why it would blow the fuse??? and also I put the good fuse in for the top oven it works like it should? Thanks Rick
I can not tell why the fuse got blown. One of possibilities (one of pretty common) is just age of the fuse. Nothing last forever.
OK thanks, i will put a new fuse in and go from there. thanks Rick:rolleyes:
