Washer goes up to the rinse cycle, fills the washer with water but will not aggitate. All other cycles work
Since all of the mechanics work I think the problem is with the control assembly, this part here.
It is an expensive part, but if you order it from this site and it does not fix things you can return it for a refund. See the returns policy or check with the customer rep when you order.
