G.E. Refrigerator Ice Maker Does Not Work
I have a G.E. Refrigerator, Model#GSS22WGPC and the Ice Maker recently stopped working. I know it isn’t the water line because I get water from the dispenser. I’ve followed the troubleshooting advice from the manual and still nothing.hThe dual water inlet valve was replaced and still no ice. The freezer fan is working and the temperature setting is at “5” for coldest and the items in freezer are frozen. I assume it is at least 0 degrees fahrenheit. Before I shell out $170, is it possible that it isn’t the icemaker but the main circuit board or something else? Is there a way to check if it is the main circuit board versus the ice maker?
it could be the head on the icemaker or the water line going from the valve to the icemaker could be frozen the dispenser and icemaker have 2 different lines…goodluck
