had purchased control panel for above followed instruction on sheet after install of control panel no response the reason for the change was the button were hard to make contact had to push several times after the new control did not work i attache old one and it worked is there something i am doing wrong this is the 2 control from parts plus:confused:
[SIZE=3][COLOR=#000000][FONT=Times New Roman]Did you program the model? This should be in the instructions but when you replace the control you have to program the model. I can’t remember exactly how this is done (if I had the instructions I would post them but I don’t). But I have done this a few times and I do know there are codes and a list of models you have to put in the correct code for your model before the control will work. [/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Times New Roman]If you are doing this correctly and it still will not work then I don’t know what to say other than you may have a faulty board. [/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Times New Roman]Clothes Washer Repair Guide[/FONT][/COLOR][/SIZE]
i have followed the instruction that came with the new unit hook-up power with bno response other than 2 clicks on the buttons re attached old one works fine other than having to push button several times
i have tried everything from checking for power to reinstalling old panel control board
