G.E. cooktop
When triing to ignite cooktop, igniter sparks but gas takes at least 1 min. to start flowing. Then it works ok. Problem is with all burners. Could this be a bad gas pressure regulator or safety valves.
Hi Jeff
There are a couple things which are very important for the proper ignition: the burner and the igniter have to be clean and dry, the burner head should be placed properly on the burner base.
To clean the igniters I would recommend to use a rubbing alcohol and to clean the burner you can use a soft metal brush.
Inspect all igniters and if you found the ceramic part of the igniter cracked, replace the igniter.
Good luck.
Hey Jeff did you ever figure it out? I have the same problem.
