G E Conversion; nat. gas to propane
Need to convert from natural gas to propane, GE says no kit is needed, just reverse orffices. How many are there and where are they located and any hints? Thanks
The conversion instructions and LP orifices can be found attached to the range next to the pressure regulator.
Here are the breakdown diagrams and Replacement parts for General Electric JGBP26GEJ4 Gas range | AppliancePartsPros.com
