The frost build-up at the back of my Frost Free Freezer is pushing the back panel forward and pulled out the screws. It continues to push the panel further and further out so that it is diffucult to close the door and keep closed. I have switched it off and de-frosted it, but it just builds up again.
I cannot find any info on this unit but it definitely sounds like you have a defrost problem.
Here are a couple good sites with info, note that a freezer is basically the same as a freezer section in a fridge.
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
http://www.applianceaid.com/frig.html
First you have to determine if you have a mechanical defrost timer or an electronic adaptive defrost board.
Odds are it will be a timer. Common locations are at the front or back on the bottom. Or if you have a control console it is often in there and there is usually a hole to allow you to force a defrost cycle.
First remove the evaporator cover in the freezer so you can see the coils.
Not do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item in Section ) till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it’s rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item in Section ) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item in Section ) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
