Brand: Frigidaire
Model Number:WFE320M0ES0
Main Symptom:Front right burner not turning on.
If you turn off the power to the range at the breaker or by unplugging the power cord, and access the console, you can test the infinite switch for continuity to determine whether the switch or the element has failed.
Here’s how to check it:
Disconnect the brown wire from terminal H2.
Turn the switch to the ON position.
Test for continuity between:
L2 and H2
L1 and H1
L1 and P
If no continuity is found at any of those points, the switch has failed.
If you do have continuity at all three points, then the heating element is the part that’s failed.
Infinite Switch - WP3149400 Range Surface Element Switch | Genuine Whirlpool OEM In Stock
Right front element - W10823696 Surface Heating Element, Top Burner Element | Genuine Whirlpool OEM In Stock
