Brand: Jenn-air Model Number: Jes 9900BAB19 Main Symptom: Burner will not heat when turned on. What happens & when: Replaced inf -switch and checked continuity in burner appeared to be okay.
Error Code (if any): na
Parts or tests already tried: inf-switch
If the other burners work, your voltage is good for the cooktop. If you replaced the infinite switch and wired it in properly, that is good. The only thing left is the element. There are contacts in the element that can go bad, even if the coils are good.
The other burners on the cook top work except the right front. The switch was replaced the wiring is in two different connectors so I am sure they cannot be connected incorrectly. There are 6 wires in the top and 2 in the bottom.
Thanks, this the same wiring diagram I have. Connection C6 yellow and tan wires are switched with each other on the factor wiring connection on the switch from what the diagram shows. Not sure if this matters.
Your checking it for continuity when it is closed or no continuity when open. The two smaller terminals are for the hot surface switch on the element, it does not matter on that one. A dual element will have an inner and outer coil with L1 going to each. Usually the switch will say 4 and 4a. L2 goes typically to the dogleg terminal on the element. There is typically 5 wires for the dual element. being you replaced the switch, it probably is good, just make sure it is wired correctly.
