Front Loading Washer will not run through a cycle
I am having some issue with my washer. I changed the belt and cleared out the drain. I started to run a cycle and once it did the wash it stopped and did not drain. I decided to run the spin cycle only and the washer fully drain and spun the clothes, it worked as it should. I then proceeded to run the rinse cycle and it worked perfect as well. If I run all the cycles individually it works great. For whatever reason it seems that the washer cuts off between cycles and will not go to the next cycle. Please help.
This sounds like a control unit problem, although with these models the door lock assembly and the speed control unit are also suspect. Try changing out the control unit.
If you buy from this site and the part does not fix the problem you can return it.
