I have a front loading Frigidaire model FWTR647GHS0 that suddenly quit tumbling in all cycles. Searching online, I found a recommendation to check the fuse in the Speed Control Panel. Mine was burned out, so I bought a replacement and installed it. Immediately after trying to start a wash cycle, the fuse burned out. That is when I discovered the Technical Data Sheet envelope taped to the inside of the cabinet. I went through all of the steps for diagnosing a motor not running, and here are the results:
- Good Power
- Good Door Switch
- Good Voltage 120Vac
- Pin 1-pin 5 120 Vac
Pin 2-pin 5 120 Vac
Pin 6-pin 5 44.8 Vac
Pin 10-pin 5 120 Vac
I wasn’t sure about where to find the timer contacts, or the exact way I was supposed to test them, but I did notice on the WiringDiagram that 1C, 3C, 5C, and 7C are all connected to the YEL/BLK wire on the WHITE timer plug. So I inserted my volt meter contacts intothe back of the white plug to do the timer contact tests.
ELECTRICAL POWER DISCONNECTED / TIMER SWITCH PULLED OUT
1C YEL/BLK-1B BLUE Continuity
3C YEL/BLK-3B PINK/BLK Continuity
5C YEL/BLK-5B WHT/RED Open
7C YEL/BLK-7B BRN Continuity
ELECTRICAL POWER CONNECTED / TIMER SWITCH PULLED OUT
1C-1B .001 Vac
3C-3B .001 Vac
5C-5B 33.4 Vac
7C-7B .001 Vac - Fuse bad
- Pin 1-pin 2 1.397 Meg Ohms
Pin 2-pin 3 1.414 Meg Ohms
Pin 3-pin 1 3.15 Meg Ohms
These are all supposed to be 3 Meg Ohms +/- 10% - Pin 1-pin 2 2.6 Ohms
Pin 2-pin 3 2.6 Ohms
Pin 3-pin 1 2.6 Ohms
These are all supposed to be 2.6 Ohms +/- 7%
I’m quite sure I wouldn’t have both the Speed Control Board and the Timer go bad at the same time, but I’m not sure which is causing the problem, and what is causing the fuse to burn out.
Any help would be greatly appreciated.
