The washer will not spin at the end of the wash cycle
Inside the lower service panel are tech notes that will tell you how to generate error codes, how to interpret them and how to put the machine into a diagnostic test mode to trouble shoot it.
Focus on the door lock assembly and the Speed or Motor control unit.
is water drained? if not there would be a pump issue, either blocked or defective, it will no spin if the case
