Front Load Washer! HELP!
My wash machine started to make some horrific noises. I shut it off and pulled the front panel. I saw that one of the shock absorbers was broke. I replaced both of them. Started it up and more noise. I opened the front door and the stainless drum is very wobbly. it moves all over the place. Anybody had this problem?
Hi.
When you replaced the shocks did you check two springs holding the outer tub on the top of the washer?
Open the rear panel and check the belt, the pulley.
If you can easily move the basket by the pulley then most likely there are bad tub bearings. They comes as an assembly with rear outer shell.
Here are the breakdown diagrams and Replacement parts for General Electric WSXH208A1WW Washer | AppliancePartsPros.com
The shell AP2047594
Thank you. Post the results.
Simon.
