front load washer f3 error code
My front load washer is showing a f3 error code can someone tell me what the problem is?
Hello bo_okie1. The F3 error code is for heater shorted to ground. You will need to test the heater between the contact and the housing. It is normally 2MW. If it is bad, you will need to replace the heater. Hope this helps.
AP6021301
Tub and basket parts replacement parts for WHIRLPOOL WFW9500TC01 AUTOMATIC WASHER | AppliancePartsPros.com
Thanks Jeff,we live where the water is really hard can this contribute to the problem and haow do i access the element?
Hello bo_okie1. To access and test the heater, you will need to remove the bottom toe panel of the washer. There are some screws across the bottom you will remove and the toe panel pulls out and down. Once removed, you will see the heater terminals on the front of the washer tub at the bottom. You can test the heater there. Hard water can cause the heater to fail more quickly. Hope this helps.
