Front Load Maytag What is Error Code f06
Cant find what the F6 error code means. Please help.
Try this:
[FONT=Swiss721BT-Heavy][SIZE=1][FONT=Swiss721BT-Heavy][SIZE=1][LEFT]Possible Causes / Procedure[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][FONT=Helvetica][SIZE=1][FONT=Helvetica][SIZE=1][LEFT]1. Verify the shipping system including shipping bolts, spacers
and cables are removed.
2. Unplug washer or disconnect power.
3. Check wire harness connections between the drive motor and
the Motor Control Unit (MCU), and between the MCU and the
Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.[/LEFT]
6. Check the drive motor for powered rotations.
Nat
