Front Door Panel replacement
The outer door panel cracked at the top hinge. I think I can glue it back, but I’d like to replace the front panel. I’m having no luck finding a repair manual online. I’ve read other posts of people who tried to replace the front door panel and had difficulty getting the latch to work properly after. Has anyone changed the front door panel on this model or do you have a service manual that you would share with me?
Here is the service manual for your model.
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;down=56
Thank you. This should help me a lot.
