Frigidaire
Okay I’m new to the site as well as appliance repair my question is about the machine not washing? It will do the initial fill but won’t wash, I took the motor out and tested it it works I was told the pump may be bad where is that and how would I check that?
Did it make any noise when it should wash?
Did it drain?
Which motor did you remove?
Here are the breakdown diagrams and Parts for Frigidaire FDB520RHB0 Dishwasher - AppliancePartsPros.com
It does make a whining noise when it should be washing I took the motor on the bottom center out number 70 in the diagram it functioned properly on a bench test, the unit drains with no problems as well.
Would the spray arms spin if you will open the door during the wash cycle?
Remove the toe panel and check if the motor which you removed earlier is working?
The spray arms do not spin, as for removing the toe kick and checking the motor it is getting power and works off of the machine. I guess I’m not sure how to check it on the machine? Does the drain pump act as the spray/wash pump as well?
If you are not sure how to check the drain pump or any other washer parts of your Frigidaire washing machine then don’t try to repair it your self. It will be better if you call a expert repairman for repairing. He is solve your problem very well. I want to add one thing your washer belt may be crack or damaged. It may have to be replace.
[quote=racer35j;795374]…The spray arms do not spin…
…as for removing the toe kick and checking the motor it is getting power and works off of the machine…[/quote]
Open the door during the wash cycle and check the water level inside. Try to add a few cups of water manually to see if the spray arm will spin.
Remove the toe panel and touch the motor while it’s on wash cycle. You should feel it.
Hey thanks for the super helpful reply. I’m not sure how I missed that thread. I haven’t quite mastered the search function on here. I think I’ll pass with him this time around. If i want any further guideline we will contact you here https://forum.appliancepartspros.com/posts/t515684-floridalottery-frigidaire
It sounds like you’re dealing with a washing issue on your machine, but don’t worry, we can help. If the initial fill is happening but it’s not washing, it could indeed be related to the pump. Here’s what you can do:
Locate the Pump: The pump is typically located at the bottom of the dishwasher, often near the drain. It’s responsible for circulating water during the wash cycle.
Check for Clogs: Before assuming the pump is bad, make sure there are no clogs or debris blocking it. Sometimes, foreign objects can obstruct the pump’s impeller, preventing it from working correctly.
Inspect the Pump: Look for any visible signs of damage or wear on the pump. If it looks damaged, it might need replacement.
Check the Pump Motor: Since you’ve already tested the motor and it works, that’s a good sign. The pump motor is a critical part of the pump assembly, so if it’s functioning, that’s a positive indicator.
Electrical Connections: Double-check all electrical connections to the pump. Loose or corroded connections can also lead to a malfunction.
If you’ve gone through these steps and still can’t find the issue, it might be a bit more complex, and you might want to consider seeking professional appliance repair services.
By the way, our company specializes in appliance repair, so if you need expert assistance, we’re just a call away. And if you’re interested in learning more about appliance repairs, I recently started a blog that might have some valuable insights. Feel free to check it out! :toolbox::wrench::laptop:
