Frigidaire
when unit is running water leaks out some place at the bottom near the pump.Is there a way to know what place its actually leakinging from and how do i fix
Here is the parts breakdown.
Replacement parts for FRIGIDAIRE FDB1050REB0 Frigidaire/dishwasher | AppliancePartsPros.com
You have to locate what is actually leaking before you can fix it.
A flashlight and an mirror can help here.
The best mirror is the type used by mechanics. It is like a mirror that the dentists use just a little bigger with an extendable handle. You could also tape a small mirror two a dowel (perhaps the wife has an old compact).
Before starting unplug/remove power from the unit and dry it off, this may help trace the leak up to where it starts.
Be very careful as the unit is live and water/electricity is a dangerous mix.
