Frigidaire Washer: Need to install new Timer
How do you install a timer for the Frigidaire Washer? Also, I want to find out the function of a timer to make sure that this is the problem (although a technician came to our house and confirmed that it was the timer).
Hi
I cannot get your model to come up, can you check the model number and make sure you have posted the right one.
The timer is basically the control unit for your washer. It sends electrical current to the motor and other areas to tell it what to do and when to do it.
Why don’t you tell us is some detail about your problem and why the tech thought you should replace the timer. We might be able to confirm the diagnosis or suggest a lower cost fix.
