frigidaire washer leaking
i replaced the transmission and tub bearing (spin bearing) and i have water leaking from the tub around the transmission shaft and running down on the belts and spraying water on the motor.is there some kind of sealer that i need? the washer is a stackable frigidaire gallery series model flse72gcs9
Did you happen to put on a new tub seal ([COLOR=#800080]AP2142342[/COLOR]) when you did the transmission? If not, this may be the source of your leak.
i did not replace the tub seal, but i just ordered one. thanks! do i need to grease any of the parts i replaced(spin bearing, outer tub bearing) or use anything on the tub seal?
No grease, just make sure the seal is pressed into place or you will put it all back together and hear some rubbing noise. Personal experience.
