Our washer came from an auction so we don’t know the age. It is a super capacity washer that works OK sometimes. Frequently, however, it does not fill. The knob that indicates the cycle does not advance either-which might be correct since the washer is not doing anything but leaking water. The water just leaks through, wasting water indefinately. What parts could we replace to fix this problem?
Frigidaire model FWS777GFSO does not fill.
