Frigidaire Washer E3 Code
Brand: Frigidaire
Model Number: FFTW4120SW
Main Symptom: Wash cycle won’t start
What happens & when: When starting a new load a clicking noise happens and an E3 code appears we have replaced the lid switch and the lock assembly exactly one week after doing that the same problem is happening
Error Code (if any): E3
Parts or tests already tried: Replaced lid switch and lock assembly
With the lid switch and lock assembly having been replaced, check the wiring between the switch and control board. If this is good then the control board would be the issue.
