Frigidaire washer dryer combo
Brand:fridgidaire
Model Number:flce7522aw1
Main Symptom:spin cycle
**What happens & when:**I have a Frigidaire washer/dryer combo
At the end of the wash cycle it will start to spin for 10 seconds or so then stop then pump for 10 seconds. It will do this several times before it spins normally for 5 minutes or longer sometimes 20 minutes depending on wash setting. After the spin cycle ends it will pump and stop repeatedly sometimes for 5 minutes or longer till I hit cancel button. Sometimes stops on its own. It goes through all the cycles just fine. This only happens at the end in the spin cycle.. This doesn’t seem normal to me. Been doing it since i moved in 2 years ago. I did a diagnostic no code.
Start with doing a clean washer cycle (possibly two or three) to get rid of built-up soap residue. Then try running as normal.
I did that once I will try a couple more times thanks
No problem, let me know if you need more help.
