Our Frigidaire oven is acting up. My wife put it in clean mode over the weekend and it seemed to be working until it tripped the breaker. Since then, we have to keep the breaker turned off because with the breaker on, the top element stays on and gets hotter and hotter, as if it’s stuck in clean mode. The element glows bright red and gets hot enough to burn the hair off your hand if you put it in the oven.
The control panel seems to work fine.
Any ideas?
Thanks,
Jack
