Hi, my dishwasher is hanging up at the 7 o’clock and 10 o’clock position on the high temp cycles. I read the previous blogs and tried it on normal cycle and it worked fine. Except the soap did not dissolve well. Based on what I read I ordered a high temp sensor from APP and installed it. This did not solve my issue. Still hangs up and dishes have a white powderish film on them.
When it is hung up it seems to have an intermittent humming sound to it.
What is the part number and location of the “sensor” you replaced?
Sounds like the problem is a faulty temp boost hi temperature wash thermostat which is located under the dishwasher, behind the kick panel. It has yellow and yellow/black wires to it.
The temp boost wash thermostat AP2108961
You replaced the high limit thermostat which most likely has nothing to do with the problem you described. This is a safety thermostat to protect the dishwasher from possible overheating. It is normally closed and opens the heating circuit if the temperature will go over the limit.
Try to replace the temp boost wash thermostat I mentioned in the previous post.
Hi Gene, Thanks for the advice I have ordered the part. If I run the washer with the high temp modes shut off should it work properly or will it still hang up? It seems to be leaving a lot of white residue on the dishes as well.
[QUOTE=sawman#268;909020]…If I run the washer with the high temp modes shut off should it work properly…? It seems to be leaving a lot of white residue on the dishes as well.[/QUOTE]
It would run but water would not hot enough to dissolve all soap.
Hi Gene, I ordered and replaced part # AP2108961 as you suggested. When I found the sensor behind the kick panel there were two sensors in one holder. The one with yellow/yellow black wires has the wrong size blade connectors on it. The one with orange/yellow wires had the same part number as I had ordered so that is the one I replaced. Washer is still hanging up and makes a pulsing hum at the turn dial when this happens. I have a pic of the two sensors in the retainer but don’t know how to post it here.
[QUOTE=sawman#268;909222]…The one with yellow/yellow black wires has the wrong size blade connectors on it…
…The one with orange/yellow wires had the same part number as I had ordered so that is the one I replaced…[/QUOTE]
According to the manufacturer wiring diagram, the temp boost wash thermostat has yellow and yellow/black wires to it. The blades size is not that critical, especially if they are a bit smaller.
What is the part number of the other thermostat with orange/yellow wires?
The part number of the sensor with yellow and orange was the same as the one I ordered 154227808. As for the other sensor blade size I could not use the sensor I ordered because the wires would not stay attached.
it now hangs up right before the drying cycle. If I advance it by hand it pumps some water out and then goes into drying mode. It is leaving white residue on the dishes.
The thermostat I replaced was connected by yellow/orange wires. Its part number was 154227808. This number matched the part that you told me to order. The sensor retainer was a double, meaning it had two sensors in it. The one you had told me to replace was the one with yellow/yellow black wires. That sensor had large male blades on it and large female blades on the wires. The wires would not stay attached to the sensor I ordered as it had small male blades on it. I also noticed the numbers did not match. It was at this time that I pulled out the other sensor, the one with the orange/yellow wire. I saw that the part # matched and the blade size was the same, so this is the one I replaced. I took a picture of the retainer but cant seem to post it here in this thread. Washer is still hanging up in two locations and I have to advance it by hand.
Hi, I finally figured out how to attach a photo. I replaced the sensor on the right. It had matching part numbers to the one that I ordered. In the background you can see where they were located. It is a two place retainer. The one with yellow/yellow black wires has the larger blade connectors on it.
Any additional help would be appreciated. AP.jpg (63.3 KB)
Open the control panel and check how the wires are connected to the options push-button switch. The switch terminals should be marked according to the color of the wires.
If they are connected wrong, reconnect them (orange wire to O, yellow/black wire to Y-BK).
If they are connected correctly, reconnect them so the orange wire would be connected to Y-BK terminal and yellow/black to O terminal.
Put the control panel back in place and give it a try.
