As the title shows I have a Frigidaire Oven/Stove top /Range model # fef326abg When i turn the Large burners on the element light comes on but i get no power or heat from the 2 large burners. The small ones work fine but the large ones won’t get any power to them.
I looke and i see no burnt wiring and there is power to the switch. I don’t know much about ranges and i have no idea what to check next.
You have a weird problem.
I cannot see how the two large elements have any wiring that is just for the two of them.
I am assuming they both went out at the same time and that everything else works properly.
I would check them for resistance, perhaps they both went out at the same time though the odds of this happening are very, very high.
Also recheck the wiring.
I am pretty well stumped on this one
Hopefully, someone else will be more helpful.
