My stackable dryer stopped heating, but still spins. The washer is still working, wondering what the problem is and if its easy to fix, if can not fix it myself can i buy a part and have someone install it. Your help is much appreciated.![]()
Replacement parts for FRG FEZ831AS1 | AppliancePartsPros.com
Here is a better wiring diagram
http://ftp.electrolux-na.com/PDFnotFoundCheck.asp?path=ftp://ftp.electrolux-na.com/ProdInfo_PDF/&folder=Webster&PDFtype=Wiring&PDFfile=134135600e.pdf&model=FEZ831AS1
And here is a service manual which may help, am not sure if it is a direct match to your unit. Also give it a few minutes to download.
http://www.frigidaire.com/tip/servicecd/Content/Laundry/5995381885.pdf
First check that you have 240 volts at the plug with a meter.
If you do not have a meter then turn the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker. The heater is the only thing that requires the full 240 volts.
Next most likely culprit is the heater itself, again best to check with a meter.
An alternate method would be to put the unit into an Auto cycle, if the timer advances the heater is probably OK. It gets it’s power through the heating coil when in Auto.
Next would be one of the thermostats again best to check with a meter.
Not sure if you can fix it yourself, depends on how handy you are and how much effort you want to put into it. It is not that difficult of a job.
[COLOR=Green]I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
To check power at the plug just put it to an AC volts scale higher that 240 and measure it.
There is a good STICKY at the start of this forum about it’s us
[/COLOR]
Thanks so much, and yes that was the other thing i forgot the timer did stop moving.
