Frigidaire side-by-side fridge side leaking under crisper
I am sure this has been answered before, but I am unable to find the post.
  • I am finding water under the bottom crisper. I see that is it leaking from the top back part of the fridge by the air outlet, not by the filter. The bottom crisper is freezing some fruit at times also. I have made sure the bottom air hole between the fridge and the freezer is clear. I am guessing there is a blockage somewhere, but not sure where to start. Any suggestion would be greatly appreciated.
Still having the problem. Anyone have an idea?
Fixed. It was the tank at the back of the fridge. It was leaking from the bottom tube inlet. I glued and will see. If it does not work I will order the replacement tubing and affix.
