Brand: Frigidaire
Model Number: GRQC225BF01
Main Symptom: Display Dead/Disabled
What happens & when: Display indicating temps and ice/water selection appears to have no power–water dispenser still works but cannot select ice or view/change temps.
Error Code (if any): N/A
Parts or tests already tried: AP6997409/5304526796
Repair tech diagnosed problem & provided me with part number for DIY replace. Accessed control board on back of fridge and replaced with appropriate part received from this site. Upon powering up the refrigerator I noted that the issue was not corrected and in addition the interior lights on fridge were not operable with the new board installed. Putting the original board back in restored the lighting but original problem persists. Tried installing new board again with same result. It doesn’t seem likely that the new part is defective in the same way the old one was broken–is there a step/procedure I’m unaware of to install the new board?
