I have a problem with the evaporator fan not running. I am not getting voltage to the fan. Is this for sure a bad adaptive defrost control or are there other problems to check first? Thanks.
If the compressor is running and there is no proper voltage to the fan motor at the same time, replace the ADC. The only other cause of it can be a broken wire which can be checked for continuity from the ADC plug to the fan motor plug.
- The ADC kit AP4909015
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE FRS6LR5ES2 Frigidaire/refrigerator | AppliancePartsPros.com
